new DX7: Operator select isnt working
t3hsd
Post by t3hsd » Sun May 20, 2007 10:28 pm
hey all
last week i bought a dx7 through craigslist and it seems to be in perfect shape
today i finally got to play it and all seemed well.
i figured out that the brown function button must lead to the bottom row of functions and it did
now i cant figure out if the operator select is broken because i cant or dont know how to get to the top blue /purple functions
please help!
also, how do you get the sustain to work via foot controls?
just pretend for all intensive purposes that im completely retarded
DX
Re: new DX7: Operator select isnt working
Post by DX » Mon May 21, 2007 10:30 am
t3hsd wrote:hey all
please help!
HI.
Talking from memory (I am not at the studio), you have to select the Blue-purple button at the left of the LCD, then select (for instance) the ALGORITHM button on the numeric pad at right for getting six numbers on the screen. 111111 . They are the operator status. If you press numeric buttons from 1 to 6, you will switch on (1) and off (0) the selected op.
Hope it helps.
Roland Promars, E-mu EMAX and some other machines...
t3hsd
Post by t3hsd » Tue May 22, 2007 5:13 am
DX wrote:
t3hsd wrote:hey all
please help!
HI.
Hope it helps.
yeah tis all good now thanks. so what is the op select for?
i see why everyone talks about the confusing architecture. the data slider is fun.
pSYCREATOr
Post by pSYCREATOr » Tue May 22, 2007 6:49 am
@th3sd
The Operator Select Button is a kind of switch. When you want to edit a Filter for an Operator, the Ratio or other things, you can swap between the Operators with this button. Choose Filter EG, press the button and you will see a number in the Display which counts 1..2..3..4..5..6, this are your Operators you can modifiy then. makes editing operator stuff a lot faster, try it for yourself.
I give up using an ASCII Logo
wich would need a longer text
line :o
t3hsd
Post by t3hsd » Wed May 23, 2007 4:46 am
pSYCREATOr wrote:@th3sd
awesome! thanks a lot
