Syncing a SQ drumtraks
michael stein
Band: S U R V I V E
Post by michael stein » Sun Jul 15, 2007 11:37 pm
How do I set the internal clock to external mode?
Thanks,
-michael-
wiss
Post by wiss » Mon Jul 16, 2007 9:06 pm
pm'd
michael stein
Band: S U R V I V E
Post by michael stein » Mon Jul 16, 2007 9:17 pm
Not sure what that means but some actual help would help. I also noticed the metrodome output is sending out 1/4 notes. Can I change this to 8ths or 16ths. Thanks.
speculator
Post by speculator » Mon Jul 16, 2007 11:32 pm
there are hidden commands.. if you hold down the faster and slower buttons at the same time and press the up and down arrows a little decimal point appears in the display.. you have to try it in the left right and center positions.. i forget which one works for what you are trying to do.. it might be all the way to the left.. and sometimes you have to hit start on the drumtracks(it won;t start, but the light will turn on) and then start on whatever you are using to control it..
get the manual.. i am only telling you this from memory.. but move that decimal point and you are golden.
michael stein
Band: S U R V I V E
Post by michael stein » Tue Jul 17, 2007 6:13 am
Thanks everyone for your help. I got lucky and found a pdf manual online. Actually a link for a long time ago post from a search. It was not directly Drumtracks related but I found it. I will try and post a link to this for others.
Thanks for you help again.
_michael-
