SEQUENTIAL MULTI-TRAK-memory prob counts from 1-6 = no sound
Posted: Wed Aug 15, 2007 3:08 pm
by erroland
Hi.
I bought a sequential circuits multi-trak a few weeks ago which has been fine until yesterday when switching on the digital display counts from 1 to 6 and i can't get a peep out of it apart from a couple of patches that contain a bit of white noise. Troubleshooting in the manual describes this problem but rather unhelpfullly just states that if this happens there may be a memory problem?!
Anyone one know of this problem, its cause or more importantly a solution. Really hoping it won't need a service as have had it less than a month. Oh, the joy of old gear.
Any thoughts appreciated.
cheers
Posted: Wed Aug 15, 2007 3:09 pm
by Altitude
dead battery
Posted: Wed Aug 15, 2007 3:13 pm
by memo
Most likely the memory is scrambled because the battery needs to be replaced.
I had the same thing happen with my Six-Trak a little while back. Once the battery was replaced, I reinitialized it and everything worked fine.
Posted: Wed Aug 15, 2007 3:16 pm
by micahjonhughes
I agree. The Multitrak counts off when the battery is dead.
The white noise on some patches worries me. Are the patches scrambled with random parameters? Are you hearing chorus noise?
You can get a basic patch by holding down record and pressing 8.
There are lots of Multitrak links in a recent thread. Look through those.
Posted: Wed Aug 15, 2007 3:19 pm
by memo
micahjonhughes wrote:The white noise on some patches worries me. Are the patches scrambled with random parameters? Are you hearing chorus noise?
Nah - he said that only some patches have white noise.
The memory gets scrambled when the battery goes out, so some patches will have the noise cranked, while most won't sound at all.
Most patches are inaudible because there are more random combinations that won't produce sound, than there are random combinations that will.
Posted: Wed Aug 15, 2007 3:35 pm
by erroland
Thanks for the advice, I was hoping it would be that and by the sound of all your experiences, it sounds positive.
will try it out. Do you reckon i'll have to go to wine country or could i pick one up closer to home, i'm in the uk.
many thanks.
Posted: Wed Aug 15, 2007 4:00 pm
by Altitude
the noise is normal, mine did the same thing. Start it up and then transfer the factory sysex patches, you will be able to use it normally until you turn it off
Posted: Wed Aug 15, 2007 4:02 pm
by memo
erroland wrote:Do you reckon i'll have to go to wine country or could i pick one up closer to home, i'm in the uk.
A local tech should be able to replace the battery for 25-35 quid.
Posted: Wed Aug 15, 2007 5:36 pm
by Altitude
I recommend you have whoever is doing it just to install a suitable battery holder instead of the normal solder on battery. The multitrak commonly has a problem where it drains the battery VERY quickly (several months in my case), so when it dies, you can just pop in a battery yourself and save some money. get used to backing up your patches also
Re: SEQUENTIAL MULTI-TRAK-memory prob counts from 1-6 = no s
Posted: Fri Feb 24, 2017 11:24 pm
by Dustydan47
My multi trak is doing the same thing, powers up counts down 1-6 but no sound, running it thru 2x12 Fender amp no sound except some ground hum which I can fix . have ordered 2 (one for spare) BR 2/3 A batteries and single battery holder to solder in . ( Just bought this from an auction house for $ 32.00 has original box and form insert . hope to get it kicking Lol
