Does anyone have any recommendations?
I see the Madell CA8016 on ebay for $150 new and it seems up to the task.
i think (iirc) that the jp-6 service notes require you to inspect the actual waveform in a few places. i'll double-check when i get home. i'd love to just get a nice fluke DMM.Altitude wrote:I would say for analogs, I would just get a good meter that has a counter. A low end fluke is about that much and do a lot more. That scope will allow you to look at the waveforms but wont tell you anything else
That may be true however your still going to need something that will output the period of the waveform and counting pulses on a screen is really not that accurate of a way to do it.StepLogik wrote:i think (iirc) that the jp-6 service notes require you to inspect the actual waveform in a few places. i'll double-check when i get home. i'd love to just get a nice fluke DMM.Altitude wrote:I would say for analogs, I would just get a good meter that has a counter. A low end fluke is about that much and do a lot more. That scope will allow you to look at the waveforms but wont tell you anything else
Even though its negative, it sounds like it might still be good enough for synth calibration work.This instrument is like most Velleman measuring equipment attractively priced but completely useless for any serious work. The specifications are very misleading and apply only to 3 of the voltage ranges (50 mV/1V and 20V). The bandwidth of 2 MHz is also only valid within these ranges. At this frequency however the scope is not able to produce a sine wave properly. Degradation of waveform in the ranges mentioned starts very early at about 1 MHz. All the other ranges behave different some are only useful to 150 kHz. Testing the scope with a Tektronix scope calibrator shows for some ranges differences for positive and negative values of DC voltages. I didn't expect Fluke quality but this is really a very inaccurate scope although the voltage values are presented with 3 to 4 digits. Only within the audio range and up to about 50 kHz acceptable measurements can be made. I own many scopes and this one definitely is not very useful to put it mildly. Any good second hand analogue scope can be obtained for the same price and will outperform the HPS10 easily.
