How do I set up 2 MMT-8's to run together at the same time?
- Alex E
- Gear: always in flux
I needed 16 tracks of MIDI, so I used a second MMT-8. I was wondering what is the correct way to take advantage of both together. So far I have both syncing together with the MIDI echo going from one to the other, but it seems that there's MIDI going out of the second one which is controlling a multitimbral keyboard (EPS) for testing, but I can't get MIDI signals from the first one. I must be doing it wrong. What should I do to make this work out? Is this actually possible? Orbital used three live so does anybody know what their technique was?
soundcloud.com/vectron
- modulator_esp
- Real name: Jez
- Gear: some synths, samplers, effects, sequencers and loopers :-)
- Band: Modulator ESP
have you got the midi echo on on the 2nd one?
if not it won't re-transmit the mid messages received from the first
mostly enjoying adventures in sound
