I never used CV gate before so im sorry if this question is too nooby.
If I want to use my Prodigy to play my Odyssey, can i do it?
What should i connect to what?
Thanks alot
CV gate question
- meatballfulton
- Gear: Logic Pro X
Most Moogs use a negative voltage trigger (called S-trigger) and the ARP uses a positive voltage trigger. A few Moogs have a positive trigger, dunno if the Prodigy is one.
The pitch CV should be compatible.
Yes, I've also heard that the Prodigy is s-trigger.
Here is an example of how to make the circuit to convert s-trig to gate.
http://www.synthesizers.com/moog_trigger-convert.jpg
