Ensoniq ESQ-1
Spiny Venutian Toads
Ensoniq ESQ-1
Post by Spiny Venutian Toads » Fri Dec 14, 2007 6:20 pm
Hi folks
I have an Ensoniq ESQ-1 I bought back in 1986 that I just took out of storage replaced the battery and started having some fun with it
my question is on some sounds like wavbell and other bell sounds and things which seem like a lot of 'verb when you go high on the board it starts popping and crackling static only when playing and its intermittant my software version is 1.70 and all in all its perfect really but those occasional pops drive me nuts
any info or ideas would be a help
thanks
WDW
Real name: WD
Post by WDW » Fri Dec 14, 2007 6:28 pm
Sounds like a cry for HELP.
WD
oops
Post by Spiny Venutian Toads » Fri Dec 14, 2007 6:30 pm
sorry still getting the hang of this
WDW
Real name: WD
Post by WDW » Fri Dec 14, 2007 6:52 pm
No worries. Heck, there are some topics that even I, a moderator, debate where they should go.
Good luck in solving your ESQ-1's problem.
WD
Analog Freak
Post by Analog Freak » Fri Dec 14, 2007 7:02 pm
Let me get this straight, your problem is that you have occasional crackling and popping in the higher registers on patches that use a lot of reverb-type effects and the bell waves? If this is the case which patches does it happen on? Does it happen with every single patch, or just a few? If it happens on all of them I would say it's a hardware issue, the audio jacks are on the right hand side and if they have loosened with age, what you are describing can happen. If it's only a few patches, start looking for patterns in these patches. My guess is that the older versions of the O.S. or wave ROMs might not have had all the kinks worked out of them, or you might just need to change some settings or parameters to make this problem less obvious. Interestingly enough, my Ensoniq ESQ-1 has O.S. version 1.70 as well, so if you can tell me exactly which patches are doing this, I might be able to try and replicate your problem and find a solution. Since you say you bought your ESQ-1 in 1986, I guess that means that mine is pretty early, although I already assumed that because the serial number is 11152. Ensoniq started their serial numbers at 10000, so in reality mine is serial #1152. Just out of curiosity, what's the serial number on your unit?
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Fri Dec 14, 2007 8:39 pm
Electrolytic capacitors and transistors. And maybe a few op amps as well.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
esq1
Post by Spiny Venutian Toads » Fri Dec 14, 2007 10:36 pm
Hi
My serial # 13268 yours is older then mine the patches are usually like wavbell gobell that sort i wil give a better reconing later
[quote= I already assumed that because the serial number is 11152. Ensoniq started their serial numbers at 10000, so in reality mine is serial #1152. Just out of curiosity, what's the serial number on your unit?[/quote]
work
Post by Spiny Venutian Toads » Fri Dec 14, 2007 10:38 pm
Hey machinengeist do you work on esq1's??
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sat Dec 15, 2007 12:15 am
I sure do. In fact I work on every possible electronic musical instruments.
One note: I've got a truckload of synths to finish the repairs. So I might not start working on your ESQ-1 before January. I'm alone in the repairshop.
You can send it anytime with USPS as long as you are not in a hurry. If you do, please include the work order (available on the website or here). I've got a room full of synths and it's getting hard to remember which synth have what problems.
You can contact me using the email button below or by visiting my website: www.MuzikElektronix.com
Thank you!
MuzikElektronix.com
Help? See TechZone
Parts? email!
Q
Post by Spiny Venutian Toads » Sat Dec 15, 2007 12:57 am
Hey cool I will look into the shipping cost another question my Casio FZ-1 needs the lcd`board I mean the whole board as the one in mine when I replaced the backlight one of the ribbons came off the lcd and I could not replace and now its all but gone the keyboard is awesome and all works perfectly but now no screen I am misty eyed as we speak can you help me with that???
thanks
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sat Dec 15, 2007 5:23 am
Sure, I can look at the FZ-1 too.
Thanks!
MuzikElektronix.com
Help? See TechZone
Parts? email!
hi
Post by Spiny Venutian Toads » Sat Dec 15, 2007 5:35 am
Hi
do you have the replacement part for the fz1? the lcd board is gonr from mine I mean all gone if you have another one I can send the keyboard and the backlight and get that fixed too let me know again I do NOT have the lcd screen or control board thats what is needed
thanks
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sat Dec 15, 2007 5:48 am
Noted.
I do not have the Casio LCD board nor the screen in stock. And Casio parts are not easily found.
BUT, I've got the service manual coming in 1-2 weeks. So I'll be able to build the board and hook up a compatible screen.
I'll let you know when the documents come in.
Thanks!
MuzikElektronix.com
Help? See TechZone
Parts? email!
solderguy
Post by solderguy » Sat Dec 15, 2007 6:45 am
Casio FZ-1 service manual here, 59 meg download:
http://www.jz-server.de/forum3/e107_plu ... rum.php?14
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Post by Maschinengeist » Sat Dec 15, 2007 6:28 pm
I guess I should have rechecked there before ordering the original. It wasn't there the last time I checked (before summer).
Thanks solder guy!
MuzikElektronix.com
Help? See TechZone
Parts? email!
