I posted this in sound production, but it probably fits here better.
I need a power supply for a KP2. If you have one for sale or know where to get please help me out!
Help finding a power supply for Kaoss Pad?
- Tyler2000
- Gear: HS-60, MG-1, CS-5, ESQ-1, CZ-101, DR-110, MR-10, MDP-40, EA-1, ER-1, ES-1, Trixer, SDS-9, Califorian 365, toys, guitars, ukes, etc.
so what do I put down here now?
'Tyler2000 wrote:The thing is that it has an interesting plug. I have an adjustable power supply, but none of the heads fit. The plug is a barrell with a pin inside. Do you think rat shack would have something like that?
The radio shack ones have removable tips. Just take the pad there and tehy usually have a keychain with all the possible tips to try out. Make sure you check what the minimum current rating is for the transformer and get one that is at least that much (it can be more, just not less)
- killedaway
- Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more! - Band: killedaway/allyourblood
- supermel74
