Inexpensive/Easy to Use Step Sequencer Suggestions
As titled, I am looking for an inexpensive/easy to use step sequencer. Any suggestions? I was thinking about a MMT-8, but found out it only does real-time. Maybe I will have to wait a while and get a Step 64.
- Dane_Xoth
- Gear: Attack uWXT Edition uQ Prophecy, W/S ex, MS 2Kr ER1 EA1 RADIAS
A X V Bk Br D SB Station,
DJ70mII R-70 S760
Spectrum Bass+Synth
FB383
Absinthe - Band: Dane[X]oth, Dortmunder
I've used an R-70 to good effect on simpler setups. Mostly triggering samples. BAsically any (more advanced) drum machine can be coaxed into sequencing external gear.
I've also used a MSQ-100, but it's only one track.
'Inexpensive' and 'easy' are relative terms (what may be 'easy' for me may not be the same for someone else)... but i would also suggest (from my experience) the Yamaha RM1x.
More info on you situation/intentions could yeild better answers...
Do you need CV outs?
How much gear are you sequencing?
Is it for live or studio?
What experience do you have?
et cetera....
D[X]
et cetera....
D[X]
Bend it to fit, Paint it to match.
Yeah, the R-70 does look like a possibility. I will have to read up on it. I can really only afford about $100 right now. The only real sequencer experience I have is both real and step on a DX200, step on a DX21, and I've used a micron. The micron was a pain (too many sub menus). I was thinking RM1X, but I think they sell used in the $150-200 range. I also thinking maybe a QX5.
- killedaway
- Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more! - Band: killedaway/allyourblood
Thanks for all the response. But to be more specific, I need at least 3 tracks and would prefer TR or grid-type step sequencer (within my under $100 budget). I've noticed Boss Dr Drum Machine sell under $100. I think a Dr5 would do what I need. Does any one know of other Boss Drs that might fit my needs?
- hageir
- Expert Member
- Gear: http://www.geirhelgi.com/
https://soundcloud.com/geir-helgi - Band: Geir Helgi
- killedaway
Revolution
Monomachine MKII
microKORG
CS01
wait -- i'm missing something. the EA/ER/ES/EM are TR style step-recording, are they not?Kaled wrote:Thanks for all the response. But to be more specific, I need at least 3 tracks and would prefer TR or grid-type step sequencer (within my under $100 budget). I've noticed Boss Dr Drum Machine sell under $100. I think a Dr5 would do what I need. Does any one know of other Boss Drs that might fit my needs?
i've owned a DR5 and a DR660, and i found the DR5 to be a gigantic pain when it comes to sequencing. it's been many years since i've used it, so its exact ins and outs are a little hazy, but it was needlessly convoluted. the DR660 was a snap, but of course, it's not really going to serve your needs.
honestly, i can't think of any other sub-$100 sequencers that can do TR-style sequencing besides the EA-1. hopefully, someone else can jump in with other suggestions. the reason i brought it up was because of your interest in the Step64, which i think can do up to 4 mono tracks, but at the expense of pattern length (16 steps as opposed to 1 track with 64 steps).
1.5.9.13
1.5.9.13
1.5.9.13
The EA-1 would be okay if it had velocity or accents. But it doesn't. If you're cool with that, it might be a good option, but I'm most definitely not.
PowerMac G4 dual, DSI MoPho, E-MU XL-7, Korg ES-1mkii, Korg EA-1, Novation Nova, Kawai K4, Casio vz10m, Casio ht700, Yamaha PSS-480
(5 good trader references and counting)
- killedaway
Revolution
Monomachine MKII
microKORG
CS01
didn't you own an EA-1? like twice? was the accent thing what killed it for you?sacredcow wrote:The EA-1 would be okay if it had velocity or accents. But it doesn't. If you're cool with that, it might be a good option, but I'm most definitely not.
i must admit, my lack of interest in velocity sensitivity, after touch, and accent/velocity-per-step control is quite liberating.
1.5.9.13
1.5.9.13
1.5.9.13
I owned one once. It was my only synth at the time and yes, basically that was what killed it. I make acid and needed something with accents. Now that the box is gone. I must admit, I do want another now, but that's because I have so much other gear that can do everything that initially pissed me off about it. It's very easy to use and has a kinda unique sound, but I can't deal with gear that neither responds to velo mesages nor has accents (nor lfos, nor full envelopes, nor cc or mod control).killedaway wrote:didn't you own an EA-1? like twice? was the accent thing what killed it for you?sacredcow wrote:The EA-1 would be okay if it had velocity or accents. But it doesn't. If you're cool with that, it might be a good option, but I'm most definitely not.
- BlackGnosis
- Real name: Stormy
- Gear: See signature image.
- Band: Eridani V
- hageir
- Expert Member
wow, I've got the same thing, couldn't care less for after touch!killedaway wrote: i must admit, my lack of interest in velocity sensitivity, after touch, and accent/velocity-per-step control is quite liberating.
anyways, if they're there, it's ok, if not = nothing to die about..
also, most synths that don't, respond to velocity+after touch over MIDI
MnM MD UW MEK Prophet REV2 16 Chroma Polaris K3 VFX ESQ-1 Odyssey Böhm Digital Drums Wavestation WS-1 MS-20 DPX-1 VZ-8m C1 Music Computer Synare PS-1 JX-3P E-MU MPC 2000XLSE-1X Polysix red SH-101 CR-8000 KPR-77 CS-15 SH-5 Matrix 6R
