OB-8 HELP!
rdemon
OB-8 HELP!
Post by rdemon » Fri Feb 01, 2008 5:51 am
All of a sudden sounds stopped coming from all the voices on one of my voice boards. I'm getting sounds from all the voices in the other voice board. The LED next to each voice is still lighting up when fired but no sound comes out.
Any ideas?
R
rjd2
Post by rjd2 » Sat Feb 02, 2008 2:34 am
my first guess is one of the harnesses. my XA, the top voice assembly flips up, there are 1(maybe 2?) harnesses that attach to it. have you tried unseating and reseating? also i would try turning it off, disconnect harness, turn on, test. do this with each harness-this should at least help you deduce which harnesses carry what, if its not obvious by routing.
best of luck.
minime123
Post by minime123 » Sat Feb 02, 2008 6:29 pm
id check connections. if not, id suspect a CEM chip or other component. but im not a tech... if its not a simple fix, id take it to a pro to fix. let us know what happens.
VINTAGE SYNTH DEALER
- https://tonetweakers.com
