drhigh5 wrote:Can I still achieve all the same great synth loops and that I have listened to sampled from from a korg kp3 or similar?
sure, if you have the KP3, just sample it and load/playback the .wav file. the Tyros 2 is able to do this. or for even more fun and easier sampling, you might want to check out their new Kaossilator.
drhigh5 wrote:I think I need to go on a course or something! I really don't understand how I can use the tyros as a sampler. I think I need to get a hard drive expansion to start with. No problem.
I think you don't really need to take a class for this
you just need some basic understanding of sampling. If you have any PC, soundfonts is an easy and cheap (even free) way to learn a hands on experiment with a multisample sampling just like you want. Also it has a huge of free library on the net. Just Download the
Vienna Editor and read everything about it, it will teach you many thing about it. You can get it
here and learn about it
here. Also if you have access to any sequencer, this free virtual
sampler is a great way to start.
no need to get any hard drive to learn, the Tyros is going to be ready for a learning purpose.
drhigh5 wrote:Are there standard sample formats that I can load into the tyros to try out?
after you have some basic understanding about sampling and multisample, you could make your own using any .wav you like. and toy around more with the Voice creator in the Tyros 2. Unless you really want to easily playing samples from a specific format, the FusionHD will be able to load soundfonts and other format such as the huge Akai library using the
Fusion converter.
drhigh5 wrote:Thanks for the tip about the Fusion HD. To confirm is this a Fusion 6HD?
Yes, your budget can even get a used 8HD to play the great piano sounds of your Tyros better.
drhigh5 wrote:I am actually after a cool retro looking little synth with knobs rather than buttons that is a contrast to the tyros for live gigs as well as professional recording.
If like this, may be what you need is actually two units, a dedicated sampler, and a VA with nice interface. I won't say that working with microkorg interface is easy, even many said that it's serviceable. If budget permit, you may want to check out the P08 which is the hottest new DCO polysynth around. But if you are ok with the microkorg smallish keys and interface, it would make a nice first time budget VA. and yes, I like the look of it too
just make sure to get the limited black reversed key edition, it will look even cooler on top of the Tyros 2 8)
drhigh5 wrote:Perhaps I need to have a lesson on the tyros if it can do the same thing?
as my experience with the S-900, while the Tyros 2 would do some good analog emulation, but not as funky as the MK, since it has features and engine that will sounds different from the Tyros 2.
drhigh5 wrote:As you say for the price it ought to do everything with bells and whistles on!
yes, the capability of layering three sounds easily (2 on the S-900) will make it capable of doing many unique sounds, surpasing a standard bread and butter sound of just a super XG module
good luck and happy sampling.
