MC-202 sequencer to MFB Synth II
I'm trying to use the MC-202 to sequence the MFB Synth II (using both channels of the 202's sequencer). Tricky though as the 202 has 1/8" cv & gate jacks and the Synth II has a one 1/4" stereo jack for CV in. I was just wondering what jack connectors I need to grab?
- Suburban Bather
- Gear: Wretch Machine, Oberkorn3, Monotribe, TR-626, FX
If I had to make the cable, I would make two cables that are both 1/8" mono to 1/4" mono and buy (or make if you are crafty or cheap) a merger connector that will merge your two 1/4" mono to a 1/4" TRS.
Like I said, you could solder the two monos directly into the TRS, but if you plan on moving this around a lot then I would just buy the merging thing. It also has the benefit of still being able to use the cables to control something else without having to resolder the ends.
Yeah, that sounds best - MC-202 plugged with two 1/8"-to-1/4" cables into a 1/4" stereo y-adapter into the Synth II. Thanks!plus321 wrote:If I had to make the cable, I would make two cables that are both 1/8" mono to 1/4" mono and buy (or make if you are crafty or cheap) a merger connector that will merge your two 1/4" mono to a 1/4" TRS.
Also if anyone else has experience with MFB's CV in, I'd love to hear tips, etc.
