Hi,
I've been trying to use the cassette tape save on my Yamaha TX81Z. My father lost the original cable years ago, I managed to figure out what the output pinout is, but I can't figure out where the pins go for tape playback into the TX for verify and load.
Does anyone have the cassette tape port pinouts?
I've looked all over Google.
Pinouts?
- nathanscribe
- VSE Review Contributor
- nathanscribe
There are three minijacks on the end of the lead, and an 8-pin DIN on the other.
The red & white jacks are 3.5mm, the black jack is 2.5mm.
Pins on the DIN plug are connected to the jacks as follows:
1
2: Red shield + White shield
3
4: Red tip
5: White tip
6: Black shield
7: Black tip
8
I think that's right. The manual doesn't provide the info (or if it does I missed it) so I just tested with a meter.
If you hold the plug on the lead towards you, so you're looking at the pins, they are arranged like this, left to right:
7 3 5 2 4 1 6
8 lower centre
Not a typical arrangement, I think. Hope that helps!
1
3
4: Red tip
5: White tip
6: Black shield
7: Black tip
8
7 3 5 2 4 1 6
8 lower centre
