I saw a post on a website or blog last year ( I thought it was on Matrixsynth) where someone had removed the original keyboard and replaced it with the kayboard from a new MIDI controller and had hardwired the controller's MIDI OUT into the PPG's MIDI IN.
Does anyone remember seeing that post? If so, please direct me to that site.
My tech called me today and said my 2.3 is almost ready to come home, but some of the keys are sticking badly. I thought the above idea would be a better alternative to having the original keyboard refurbished.
EDIT:
NEvermind, I just found it:
http://www.seib.synth.net/ppg/mods.htm
Thanks,
Z
PPG Wave Keyboard Mod
- Z
- waveterm
- Gear: A lot more than you
Before doing such a mod, try it out via Midi first. You´ll get a small delay via the Midi input. If you want to use the PPG in a midi-system it doesn´t matter but if you like to play on its own keyboard it can be distracting.
I´m talking about a very small delay but if your name Dve Gamson you´ll feel 1ms delays easily.
It´s all about the feel.
WT
WT
Just a guy with a bunch of blue things.......now, move on !
- Z
I have not had any of the bushings replaced. My original intent was to just get it operational and use it in my MIDI system.
I guess I'll go ahead and pick it up from the tech and bring it home to see how bad the keyboard really is and how it resonds with MIDI. I'll decide then if I want to order the parts from Alex @ Virtual Music or try to put in a modern MIDI controler keyboard.
Thanks for the tip, WT! You da 'blue' man!
Z
Z
- calyx93
- Gear: PPG Wave 2.2, μWave (x2), Roland JP6+V-Synth+S-220, SCI P5+600, Ensoniq SQ-80, Kawai K-3+K-3m, ARP Odyssey+Omni2, Emulator II+HD, Ensoniq Mirage.
Hey Z - here's the page with the modified Wave.
Just scroll down a bit.
http://www.hermannseib.com/english/synths/ppg/mods.htm
I'd eschew this mod for the hour or so that you might spend on rebushing the keys - not as difficult as it seems, just requires some patience. Personally, I like the one from Virtual Music.
Good luck with your Wave's recovery - keep us posted
- calyx93
It is a very strange sensation to activate the aftertouch - the whole thing does move down - somewhat of a sickening "am I going to break it?" sensation. If you've ever seen anyone energetically playing one, you would be convinced that the up and down wobbling would surely (and shortly) be the death of the synth - but it holds up remarkably well.
Upon receiving my first one, the former owner fixed the keyboard assembly to be rigid - not able to activate aftertouch. That was quickly remedied, though
However, the keys are no worse than any Pratt-Read keyboard of the Wave's age - they all go wonky like bad teeth after the bushings fall apart/disintegrate and the "tongues" get bent. I've seen plenty of Polymoogs, Prophet 5's, and Oberheims with the same problems and they feel just as bad - clunky, clicky and sticky.
