MIDI/Sequencer problem (Rogue,MCV4,BassStation,ER-1,MMT8)
Kalu
Post by Kalu » Thu Feb 28, 2008 7:50 am
I'm new into hardware MIDI-sequencing.
When playbacking a sequence, my Moog Rogue changes the note. When I play it alone, the note is right. When I play it via Novation, the note is right. But when the Alesis plays a sequence, the Doepfer/Moog change C to F (for example) while Novation is playing C as C like it was when recorded.
Sorry my bad english.. Hope you understand???
Current setup:
Alesis MMT8, MIDI OUT>MIDI IN Korg Electribe ER-1, MIDI THRU>MIDI IN Deopfer MCV4 (Rogue),MIDI THRU>MIDI IN Novation BassStation keyboard, MIDI OUT>MIDI IN Alesis MMT8.
Is this ok like this? Should I change something?
Altitude
Post by Altitude » Thu Feb 28, 2008 1:19 pm
I would look at the transpose settings or the scaling of the doepfer and make sure it is correct for the moog
Kalu
Post by Kalu » Thu Feb 28, 2008 1:35 pm
Altitude wrote:I would look at the transpose settings or the scaling of the doepfer and make sure it is correct for the moog
How to do that?
Altitude
Post by Altitude » Thu Feb 28, 2008 6:18 pm
try connecting the midi out of the Bass station to the doepfer and see if it works correctly, if it does, the problem lays in the MMT-8 somewhere. Look for anything that relates to transpose in the manual
Kalu
Post by Kalu » Thu Feb 28, 2008 7:16 pm
Thanks for your answers!
When connecting midi from bass station to doepfer/moog, the moog plays wrong note when playing bass station.
So the problem's in the Doepfer?
Kalu
Post by Kalu » Thu Feb 28, 2008 8:40 pm
OK, it works by transposing the Moog-track to desired note on MMT8.
Simple.
Me, stupid.
Altitude
Post by Altitude » Thu Feb 28, 2008 10:56 pm
Kalu wrote:Thanks for your answers!
I would focus on that, since it is the solution. transposing the MMt is only the fix :)
