MS2000 + MIDI / USB
SteveW
MS2000 + MIDI / USB
Post by SteveW » Wed Mar 12, 2008 3:23 pm
Hi Guys, ok here we are again, I bought this USB to Midi interface from Ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=017
Ive hooked it into my MS2000 but I dont seem to be getting anywhere, I have it installed as an USB audio device, and the drivers seem to be working. However the USB device is running, and in ACID i have it setup and i have loaded a midi file, and and tried to get the synth to play some keys, but its just not happening.
Ideas?
Re: MS2000 + MIDI / USB
Post by meatballfulton » Wed Mar 12, 2008 4:17 pm
SteveW wrote:I have it installed as an USB audio device, and the drivers seem to be working. ?
It's not an audio device!!! That is the root of your problem.
Go to the MIDI tab in the Preferences dialog and you should see your interface device (not the MS2000) there for selection.
Good luck.
SteveW
Post by SteveW » Wed Mar 12, 2008 5:21 pm
ok I have it sending out a midi clock, so i know it works sort of, so i think i have to set the software to the right midi channel. maybe?
SteveW
Post by SteveW » Wed Mar 12, 2008 6:58 pm
bloody sound editor says no device attached.
AH!
Altitude
Post by Altitude » Wed Mar 12, 2008 7:07 pm
you will need both the in and out for an editor to work
SteveW
Post by SteveW » Wed Mar 12, 2008 8:46 pm
k heres an update, found the problem, the midi cables were labelled wrong, using midi-ox i have got midi working although sometimes a key sticks when you play midi. and the editor still doesnt connect.
Steve
SteveW
Post by SteveW » Wed Mar 12, 2008 8:52 pm
Steve
