mpc 60 and din
How can I start and stop DIN sync devices with an mpc 60? Not reset to the beginning of course. Is there a midi to din device with multiple Din outs?
- wiss
- Gear:.com, mpc, and a studio full of behringer clones.
are you still running the orginal OS?
the I believe that output 4 is a sync channel. You have to set prior to the sequence...
if you've upgraded the OS, the 4th output is no longer a Sync and just midi
