Electribe L/mono Out socket replacement?
pricklyrobot
Post by pricklyrobot » Mon May 19, 2008 2:56 pm
A friend just gave me a free ER-1 (mk I), after a bit of repair (i.e. soldering the power socket securely back onto the board to stop the thing constantly shutting off) it works fine.
Except the L/mono Out socket seems to be faulty. I checked it out when I had the thing open and it seems to be securely attached to the board. I can get sound out of it if I push down hard on the cable that's inserted into it. So I'm thinking there's something loose or broken inside the socket.
Does anyone know where I can get a replacement part? Or even what the technical name for this part is (Audio Out socket, jack?), so I know what to search for?
gmeredith
Band: Warning Will Robinson
Post by gmeredith » Wed May 21, 2008 4:09 am
The socket would be the same as the EM-1. In the EM-1 service manual, it lists the part as an output socket, part no. LGR4609-7000.
You could ring Korg support for how to get one off them, or go to KorgParts.com here and contact them:
http://www.korgparts.com/content/estore ... tname=Korg
Cheers, graham
pricklyrobot
Post by pricklyrobot » Wed May 21, 2008 3:27 pm
Thanks Graham.
I tried doing a Google search on the part number, but that only brought up Japanese language sites. So I've e-mailed korgparts.com to see if they can help.
P.S. I came across your CZ battery back-up info on another forum: http://www.jz-server.de/forum2/e107_plu ... ic.php?596 Wired it up to my CZ-1000 the other day (except I left out the diode because I am using NiMH rechargeable AA's), seems to be working nicely so far.
:D
gmeredith
Post by gmeredith » Thu May 22, 2008 12:12 am
Hope you can get the socket ok.
Glad the CZ battery mod worked well!!
Be aware, though, that NiMH batteries don't hold their charge as well as alkaline non-rechargeables. They actually run down over a couple of months just sitting around.
Cheers, Graham
pricklyrobot
Post by pricklyrobot » Thu May 22, 2008 12:20 am
gmeredith wrote:NiMH batteries don't hold their charge as well as alkaline non-rechargeables. They actually run down over a couple of months just sitting around.
Yeah, I just hate buying non-rechargeable batteries. I reckon I'll keep an extra set of four around, and routinely swap in a freshly charged set every two months or so.
Thanks,
Joshua
hfinn
Post by hfinn » Thu May 22, 2008 12:36 am
Wow, You're right around me (Boston)
pricklyrobot
Post by pricklyrobot » Thu May 22, 2008 12:45 am
Not for long. I'm moving (back) to Austin, Tex-a*s in August. I can't handle New England's Puritanical weather (we are wicked sinners who deserve only cold aire and grey skies) any longer. :wink:
killedaway
Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more!
Band: killedaway/allyourblood
Post by killedaway » Thu May 22, 2008 3:48 am
gmeredith wrote:The socket would be the same as the EM-1. In the EM-1 service manual, it lists the part as an output socket, part no. LGR4609-7000...
might you know if the service manual is available online? i've been snooping around for any of the 'tribe manuals to no avail.
1.5.9.13
1.5.9.13
gmeredith
Post by gmeredith » Thu May 22, 2008 6:29 am
Sure! It's in the FILES section of the Yahoo Electribe group:
http://launch.groups.yahoo.com/group/electribe/
You'll need to join up as a member there to access the files section, though.
Also, the EMX service manual is here:
http://electribe-forum.com/viewtopic.php?f=3&t=16
If you ever find the ES-1 service manual, let me know!
Cheers, Graham
th0mas
Band: GRAVITRONIC
Post by th0mas » Thu May 22, 2008 4:42 pm
If you cannot find a suitable replacement jack (either the official part or a substitute), you could always do something gross and find a cable with a 1/4" female end and solder it directly to the board :D.
killedaway
Revolution
Monomachine MKII
microKORG
CS01
& more!
Post by killedaway » Thu May 22, 2008 5:53 pm
gmeredith wrote:Sure! It's in the FILES section of the Yahoo Electribe group:
i'm lame. i've been a member there for years, since 2005. how could i have missed this? anyway, thanks! if i find the ES-1 manual in my travels, i'll be sure to PM you with a link.
1.5.9.13
1.5.9.13
