Octave Cat -problem fixed!
Posted: Tue Sep 16, 2008 2:41 am
So I posted about an issue I was having earlier this year. Can't find the post for some reason, but I thought I'd follow up with the solution to my very strange problem.
I had opened up my original A-rev Cat to remove the bloody annoying calibration caps from the inside. After closing everything back up, I suddenly had no keyboard CV control... A note played when you pressed the key, but only ONE note. Tried all the usual unplugging/replugging connectors to no avail. Everything else worked as it should-just no keyboard control.
What had essentially happened was that my (apparently) slopping screwing in of the main board screws caused a short to the keyboard CV section-hence no CV. Apparently there is nothing to block the screw from accidentally connecting with the board trace, so it was not very hard to do.
So something to be aware of if you have one of these older models and need to get in there to calibrate it.
