Hi again everyone!
Ok, I'm trying to link my proteus real time controls to the midi cc's on my axiom. I set my midi cc numbers to equal my real time controllers functions on my proteus but it didn't do anything. I'm in midi omni mode and my Knobs midi out function is set to transmit if any of that makes a difference. Is there a setting that I need to change to make this work or am I doing it completely wrong?
Thanks in advance for your help guys!
Andrew
Axiom61 Controller with proteus 2000 Midi CC help.
dizkneelande
- meatballfulton
- Gear: Logic Pro X
Re: Axiom61 Controller with proteus 2000 Midi CC help.
Are you using a MIDI cable between the Axiom and the Proteus or is there a PC in between?
dizkneelande
I'm running my axiom to the proteus and then from my proteus to my pc.meatballfulton wrote:Are you using a MIDI cable between the Axiom and the Proteus or is there a PC in between?
dizkneelande
I fixed it. Thanks everyone for you help.
