Peace!
Scott
Altitude wrote:Did you make sure you got the right type of transformer? i.e. AC to DC vs AC to AC
That's your problem then, the input needs to be AC or it won't work. How did you check the setup/local control on if you were using the DC supply? I seem to remember that using a DC supply on a Micron made the lights turn on but nothing else, maybe I just remember wrong.nsbhp2 wrote:Altitude wrote:Did you make sure you got the right type of transformer? i.e. AC to DC vs AC to AC
Altitude, which would I need, as the Micron is marked 9V AC at the plug (on back of synth), and the adapter is 9V DC output. I guess I should have paid more attention while I was at the Shack.
Peace!
Scott
Other than not producing any sound, everything else seemed to function fine. I was able to access all menus and such. Now, I have another question. Why is it that all other electronics I have with wall-warts go from AC to DC, but the Micron is the freak and is AC to AC?Stab Frenzy wrote:That's your problem then, the input needs to be AC or it won't work. How did you check the setup/local control on if you were using the DC supply? I seem to remember that using a DC supply on a Micron made the lights turn on but nothing else, maybe I just remember wrong.nsbhp2 wrote:Altitude wrote:Did you make sure you got the right type of transformer? i.e. AC to DC vs AC to AC
Peace!
Scott
Anyway, get yourself a 9VAC supply and it'll work fine.
