Synth Pads
Eyebeamssuper
Synth Pads
What are some the better synths for pad sounds?
Re: Synth Pads
I've had good luck with my Juno-106 and JP-8080. What I do for pads is just take the frequency slider pretty low, make the resonance a bit higher than that, and finally play with the envelope slider to dull it out some.
Reverb and delay effects can help too.
- Z
Re: Synth Pads
The JD-800 is my "go to" synth for pads. Just about any synth will make great pads, it just takes a little bit of programming. And as Darren suggested, reverb & delay.
Check out this thread for great pad examples from our fellow VSErs.
- crystalmsc
- Band: Crystaline
If I should only pick one, it's going to be the uWaveXT. It cover wavetable, analog/rompler style pad, it can make a big layer in the performance, just my pick for an all around pad machine.
Kaossilatron - Voicillator
Re: Synth Pads
Price range?
In my experience:
Access Virus (B & Ti from personnel experience)
Elka Synthex
Roland V-Synth
Roland XP Range.
In my experience:
Elka Synthex
Roland V-Synth
Roland XP Range.
