help - wall mounting synths
Tridact
Gear: Roland MKS-80,Alpha Juno,JX-3P,SH-09,R-70,TR-707,TR-505,Moog MG-1,Korg Volca Bass,ER-1,Yamaha DX-200,Boss DR-55,DR-110,SP-202,Emu ESI-32,Casio RZ-1
Band: tridact
Post by Tridact » Mon Oct 27, 2008 10:23 pm
Does anyone wall mount their synths, kind of like how they do at music stores? I'm thinking of getting something like this:
https://www.stringswing.com/products/pr ... _category=
I'm wondering if they do too much damage to walls to be worth it (I know the DX-7 would be out of the question). Otherwise I think it would a great way to utilize my limited space. Anyone have experience with something like this or something similar? Any other suggestions?
Thanks.
Z
Re: help - wall mounting synths
Post by Z » Mon Oct 27, 2008 11:26 pm
I thought about buying slat wall like what guitar center uses, but I'm not sure if they make brakets large enough (or strong enough) for larger, vintage analog synths. Instead, I'm chopping up a bunch of "A frame" stands.
If you do use those type of wall mounts, be sure to anchor them to studs.
Tridact
Band: tridact
Post by Tridact » Tue Oct 28, 2008 12:26 am
Yeah - I would definitely anchor them to studs. I think most of my old synths are light enough.
Regarding slatwalls - I've seen some pretty big and heavy synths on those, so you might not rule them out as an option.
JMP
Post by JMP » Tue Oct 28, 2008 5:30 pm
I've used standard DIY flexi-shelving to do this:
The top two angled sections by making shelves with angled supports:
Likely more work than those you've pictured but they're strong, only two 50cm long arms to support a Synthex and an OBXa separately. These are reported to be strong enough to hold 50kg of weight, although the wall mounting strips have to be fairly well screwed into wall bricks, not partitions unless you screw into the timber frame. The foam coverings are water pipe lagging.
Mine took a fair amount of work including making the EMU II cabinet (with two 3U sections below side by side) but worth it to get more synths in a congested space. :)
Tridact
Band: tridact
Post by Tridact » Tue Oct 28, 2008 10:27 pm
That's a really nice setup. I might consider doing what you've done there, even though I fear using a table saw.
JMP
Post by JMP » Wed Oct 29, 2008 12:03 am
Tridact wrote: I fear using a table saw.
A hand held jigsaw is nothing to use and does the job great with a steady hand. :)
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Wed Oct 29, 2008 9:54 pm
Quick question for JMP:
How do you reach the two bottom synths? Lie on the floor? Play with your toes? :)
JMP
Post by JMP » Wed Oct 29, 2008 10:32 pm
Heh, I have a stool for the OB when needed and it's a cross-legged sitting affair for the EMU. Not too easy for an unfit 38 year old. OK whilst you're there, but try stand and straighten up afterwards...aarrggh.
