help sync moog source to tr626 or pc
echoplex
Post by echoplex » Tue Oct 28, 2008 12:31 pm
Hi
i need help i want to sync a moog source to a Roland tr-626 and that to a pc
will it work ? how to do it ?
Cheers
echoplex
Z
Re: help sync moog source to tr626 or pc
Post by Z » Tue Oct 28, 2008 4:01 pm
I did not see anything in the Source manual regarding the ability to sync its sequencer to an external device. However, I did see one photo online when I seached "moog source" on Yahoo Images that showed a 5 pin DIN jack that was labled "sync in." This same jack is labled "cassette interface" in all other photos. I'm not sure if the Source in that photo is a later version from Moog or if it had been modified. If that was indeed a DIN sync jack, then all you would need is a MIDI to DIN sync converter just as you would need for early Roland drum machines.
If your Source does not have this sync in jack, I do not see a way to sync its sequencer with an external device. However, you can purchase a MIDI to CV/Gate box and play the Source as a slave sound source via MIDI.
Best of luck.
echoplex
Post by echoplex » Wed Oct 29, 2008 12:07 am
I downloaded the manuals for both the Source and the Tr626
do you think it can be done??
The source
Trigger in
- the source's contour generators will be triggered whenever an S-trig (shorting connection ) appears at the input portion of te Trig Jack
it may be generated by another synth or a simple mechanical switch closure.
such a closure must be opened and reclosed to generate any successive triggers.
Trigger in is connected to the ring of a stereo jack ( trigger out on the tip )
TR 626
trigger out
when a rim shot sound written into a pattern hrough trigger outis generated , the trigger messages (+5v approx 18ms ) are output through trigger out jack
cheers
echoplex
Z
Post by Z » Wed Oct 29, 2008 12:41 am
The Source's Trigger In is a Switch Trigger also known as Gate on other instruments. Like you read from the manual, the trigger in will initate the contour generator for whatever current key has been played. So if you progammed a rim shot rhythm on the 626 and plugged the 626's Trigger Out to the Source's Trigger In, you might be able to pull of some sort of arpeggiation of whatever key has been depressed.
echoplex
Post by echoplex » Wed Oct 29, 2008 2:26 am
i connected a mono cable to the source trig in/out from the tr626 and it made the source sound a continuous tone
this was without a rythym pattern playing on the tr626
Z
Post by Z » Wed Oct 29, 2008 3:15 am
Well, I'm out of ideas. Your best bet would be to get a MIDI to CV/Gate converter to control the Source from your other MIDI gear.
Best of luck!
redchapterjubilee
Post by redchapterjubilee » Wed Oct 29, 2008 2:57 pm
I've not tried this with DIN-SYNC but...yes, when you plug an audio cable into the trigger-in the synth will drone. Once you send it signal it will trigger the envelopes. That is how I can get the auto-repeat to sync with Reason.
cornutt
Gear: 6th
Post by cornutt » Wed Oct 29, 2008 9:13 pm
It's the imfamous Moog S-trigger. You need a converter for that.
echoplex
Post by echoplex » Thu Oct 30, 2008 1:48 am
ok i found a solution perhaps will have to make up some cables and test it
http://www.synthesizers.com/gates.html
http://www.synthesizers.com/moog_trigger-convert.jpg
