Jomox xbase 09 issue.
- Hypercomplex
- Gear: Jomox Xbase 09, Delta 1010, ReFX Vanguard, Glitch, Acid pro 6
- Band: Hypercomplex
So i just bought an XBase 09, when i plugged my headphones into the mix out jack all i got was sound through the left ear at very low volume. i took it to a friends house and we tried running it through his set up. we tried to hook it up every which way through his mixer and delta 1010 interface. it would only register on the left, though we were able to get sound from left to right but we could only record to the left side. he had a spliced cable that we plugged in that should have split it to left and right but it was a balanced output and i guess i need an unbalanced output. this is my first piece of hardware so maybe im missing something? hopefully the right channel isn't just fried. hopefully i can get some insight to this issue.
- space6oy
Re: Jomox xbase 09 issue.
it's a mono output. mix just means it's all of the instruments.
- Hypercomplex
so when im recording i can only record through the left? how can i even it out so that it plays correctly? reguardless of how im routing it, the left will only register, shouldn't it register equally if its mono output?
- space6oy
you also need to keep the master volume up all the way on jomox gear, otherwise it does strange things...
for sale/trade: EML-101
- space6oy
mine definitely does strange things, but there's nothing weird about the volume...nadafarms wrote:you also need to keep the master volume up all the way on jomox gear, otherwise it does strange things...
Me either, other than build quality.pflosi wrote:i have absolutely no problems with my xbase 09...
guesswho
Roland JP-4/Roland JU-1 w/PG-300/Nord Modular G1/M.A.M. ADX1//Casio CZ-1000/doepfer MAQ 16/3/waldorf Pulse+/waldorf micro Q
guesswho
- space6oy
you've gotta be kidding...guesswho wrote:Me either, other than build quality.pflosi wrote:i have absolutely no problems with my xbase 09...
- jaypodesta
+1space6oy wrote:mine definitely does strange things, but there's nothing weird about the volume...nadafarms wrote:you also need to keep the master volume up all the way on jomox gear, otherwise it does strange things...
Up goes down
Down goes up
That's a quirk, and switchable in the interface. Build quality on my SE is perfect, and OS is rock solid (2.09). Upgrade if you don't have that version - I am completely satisfied with the experience and find no faults or bugs.Up goes down
Down goes up
- jaypodesta
I'm on 2.09 already.
How is it switchable?
Wasn't to difficult to find in the manual, I had to switch mine also. I'm running 2.09 and it's still full of odd bugs. It arrived from the factory that way, so I'm not really keen on Jomox.jaypodesta wrote:I'm on 2.09 already.
- jaypodesta
What a great feature!
Not.
Ta for the tip.
Not.
Ta for the tip.
Not at all. The encoders used must cheap. Extremely wobbly.space6oy wrote: you've gotta be kidding...
guesswho
guesswho
