Noisy outputs on micro modular.-.
electro funker
Post by electro funker » Tue Jan 13, 2009 6:05 pm
Yep, my micro modular sounds like a old LP (not little phatty, though that could be cool!), and it's not the cables, all off the outputs, both 1 & 2 + phones, can I it fix in some way?
-Electro Funker
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: Noisy outputs on micro modular.-.
Post by Maschinengeist » Wed Jan 14, 2009 8:19 am
You can fix it by replacing both op-amps driving both outputs. I don't have the service data under the nose but it's very likely and common (even more these days with SMD components). Desoldering is easy, resoldering is trickier but not impossible.
Please have the op-amps checked.
Hope that helps
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
electro funker
Post by electro funker » Wed Jan 14, 2009 10:03 am
OK, thank you, do you know where to find the components..?
masstronaut
Post by masstronaut » Fri Mar 06, 2009 8:13 pm
Don't know if this is related, might be something slightly different, or perhaps not.
I picked up a used Micro and sometimes on certain sounds there's a kind of digital grunge / 'aliasing' effect. I don't think it's normal behaviour as otherwise the machine sounds so pristine.
This effect is quite audible here* on the factory '8 voice piano' patch. It's definitely more pronounced on the right output.
http://www.mediafire.com/?ymfyyyhuzoe
Anyone know what that might be caused by?
Thanks in advance.
* You probably won't hear it on laptop speakers. It's the crackly grunginess - the rising whining at the start seems to be something the mp3 encoder has kindly added into the mix. Digital audio eh?
masstronaut
Post by masstronaut » Sat Nov 21, 2009 1:02 am
Can someone with a Nord Micro or G1 do me a favour?
I'm trying to work out if this 'aliasing' effect is usual.
Here's a sound example it's just a low sine oscillator tone (146.8Hz) rising and falling in volume. As you can hear, at a certain point there is a a higher tone, it sounds like aliasing or PWM or something. It starts and stops quite suddenly at a given level, quite pronounced at times.
Audio clip - http://www.mediafire.com/?z0nihtknkyo
The patch - http://www.mediafire.com/?nnwyo52mdw1
Thanks alot if you can help with this.
