sorry for the delay, I had to go collect a friend. But I have made some excellent progress...
jaypodesta wrote:Have you tried only connecting the x0xb0x and the 606 together?
yup I tried everything with no luck
nathanscribe wrote:Also, not all MIDI cables are compatible with DIN Sync connections. MIDI uses different pins to DIN Sync, and some MIDI cables are wired up only with the MIDI pins connected. If you haven't got a multimeter or something to test your cable with, you can use a standard 5-pin DIN audio lead, wired pin-to-pin. They're commonly available in electronics shops, etc.
Thanks Nathan
That was my theory (albeit with less know-how
) and I was planning on getting hold of some tomorrow...
space6oy wrote:know some may not work, but my revo, x0xb0xes and 606 all communicate fine via cheap midi cables from radio shack. grab a pack of those to try, only costs a few bucks and it never hurts having a few more cables.
Cheers Space6oy, when I saw your tip I had tried all the cables I could find but I thought "i'm sure I had one more" so I had a rummage around and found it. I plugged it in feeling like Charlie opening a Wonka Bar, pressed play and... TA DAA!!! everybody is talking to each other
Thanks so much guys!!
