Casio CZ-1
Ohm's Law
Casio CZ-1
Post by Ohm's Law » Thu Feb 05, 2009 2:14 am
Hi all,
Anyone know if replacement buttons can be found for the Casio CZ-1's front panel board?
Probably the same as the CZ-3000 and 5000.
Thanks,
Tim.
Moog Prodigy, Moog MG-1, Moog Liberation, Roland Juno 60, Roland SH-101, Roland MKS-80 super Jupiter, Roland SH-3a, Roland JX-305, Roland Sh-32,
Korg MS-10, Nord Micro Modular, Casio CZ-101, Univox Maxi-Korg, Yamha CS-01.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Casio CZ-1
Post by rhino » Thu Feb 05, 2009 2:17 am
IIRC Steph at [email protected] has one to part out.
next, try vintageplanet.nl
- Confucius
Maschinengeist
Real name: Steph. J
Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
and more stuff
Band: Cybernetik
Re: Casio CZ-1
Post by Maschinengeist » Thu Feb 05, 2009 3:55 am
I've got them all, in perfect condition. Just drop me a email at the already given address. I'll be pleased to serve you.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
Re: Casio CZ-1
Post by madtheory » Thu Feb 05, 2009 1:48 pm
Just checking- (assuming the buttons are on the panel, but not working) have you made sure that there is no dust and dirt in their contacts, and that the front panel and associated circuit boards are lined up properly?
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Casio CZ-1
Post by rhino » Thu Feb 05, 2009 8:07 pm
madtheory has a good point that i overlooked. i assumed you meant the plastic buttons and their lettering were worn or broken. if they just don't work reliably, you may need to change the little "tactile" switches under them. Mouser Electronics has them for about $0.35 each. these little things are remarkably long=-lasting...the only major problem was on the Roland JX-10: they (roland) put a sheet of black foam under the plastic buttons to stop them from rattling. the foam disintegrated into powder and worked its way right into the switches stopping them dead.
- Confucius
Ohm's Law
Re: Casio CZ-1
Post by Ohm's Law » Wed Feb 11, 2009 1:18 am
Guess I should have been more clear.
I need the tacticle switches.
Was on mouser but wasn't sure exactly which one.
Would you happen to have a Mouser or Allied part number?:)
Thanks,
Tim.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Casio CZ-1
Post by rhino » Wed Feb 11, 2009 9:05 pm
i've got mine all closed back up, so i can't see the tact switches, but I'll bet they are
Mouser 688-SKHCBFA010 from ALPS.
pm me with your mailing address and i'll send you a couple to test out before you pay shipping from Mouser.
- Confucius
