I got this synth a year or so ago, knowing these keys were bad, and figuring it would wind up being the contacts. The three keys in question are F#, B, and G. Keys #14, 19, and 27 if I'm not mistaken.
It took me until yesterday to ever take the time to take it apart and clean the contacts. With hopeful anticipation I put the rubber pads back on and hooked it up. They are still dead.
Anyone have any ideas here?
Thanks!
sh-101 dead keys
starcade_express
sh-101 dead keys
-bryan- roland sh-101, realistic/moog mg-1, korg poly-800II w/moogslayer, roland tr-505, roland csq-100, telecaster custom re-issue, electro-harmonix big muff, marshall amp.
- killedaway
- Gear: Electribes x 6
Revolution
Monomachine MKII
microKORG
CS01
& more! - Band: killedaway/allyourblood
Re: sh-101 dead keys
if you can, while the synth is powered on (and using care, obviously), try jumping the contact points without the use of the rubber pads, or use the pads from the keys you know are still working. if the notes sound, your pads have just lost conductivity, and this can be remedied.
(sorry if this isn't possible -- i've never seen the inside of a 101.)
1.5.9.13
1.5.9.13
1.5.9.13
starcade_express
yeah, it is possible. i should have mentioned that i tried it. no luck. that was my second hope after cleaning the contacts failed.
thanks tho!
thanks tho!
