Yamaha DX-7 Help
charlesm20
Yamaha DX-7 Help
HI, i have two yamaha dx- 7.change them the battery and now itself does not sound. listen that it there was that reprograming. help please.. Very Thank
- killertofu
Re: Yamaha DX-7 Help
If you have the DX7 MK1, this info will apply. You need to connect your DX7 to a computer with a Midi cable (Computer Midi Out to DX7 Midi In)
Turn on the DX7. Press the green "MEMORY PROTECT- INTERNAL" button.
Press "No -1" to turn off memory protection.
Press "Function" then press the #8 twice. The screen should say "SYS INFO UNAVAILABLE."
Use the Data Slider until that value says "SYS INFO AVAILABLE"
Then use a program of your choice to reload the sounds. I am on Mac and like to use SysEx Librarian.
If you look around on google you can find the original banks, plus many many more.
Good luck!
Good luck!
