Akai AX80 Preset Casette Needed PLEASE
denco
Post by denco » Mon Apr 13, 2009 3:31 pm
Hello,
I have been looking for 10 years for a the preset casette (copy) willing to pay. I loaned my AX80 to a band as a favor, got it back all jacked up. Bought the AX80 new in about 85, now it sets wrapped up and cant use it!! I look around every once and a while now found this site. Any help is VERY appreciated. And or any info on how you can restore it without the casette. I am not all that handy with this stuff so building my own sound bank from scratch is not an option fo me....
Denis
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Akai AX80 Preset Casette Needed PLEASE
Post by rhino » Mon Apr 13, 2009 4:58 pm
the 32 presets patches in bank "P" are in ROM and cannot be erased...they should still be there. i had no luck finding a tape of the original "A" and "B" banks. i have a AX-80 in the shop now. will be a while before i get to it, but i intend to do a tape dump before i change the battery, and i can send you a copy. it does not play right now. so i have no idea if there any patches left, or if the are original or user-made.
Kid Nepro list no patches for sale, so if i can't dump any useable for you, you'll just have to make you own.
as a last resort, the service manual has the factory a and b banks printed out as a spread-sheet. i can send you a copy and with patience, you could poke them back into the synth number by number.
- Confucius
denco
Post by denco » Tue Apr 14, 2009 2:57 am
rhino wrote:the 32 presets patches in bank "P" are in ROM and cannot be erased...they should still be there. i had no luck finding a tape of the original "A" and "B" banks. i have a AX-80 in the shop now. will be a while before i get to it, but i intend to do a tape dump before i change the battery, and i can send you a copy. it does not play right now. so i have no idea if there any patches left, or if the are original or user-made.
PM sent and thank you. My PM is prolly a little off as I was asking question from memory of this post. But sounds like it can be done I just need to get a little more edjumacated on this subject of patches and the like :D
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Tue Apr 14, 2009 3:11 am
well, let's get started.
there is room for 96 patches (sounds) in the ax-80. there are 32 in bank "A", 32 in bank "B", and 32 in bank "P".
the 32 in bank "P" are permanant: they are burned into the memory at the factory and cannot be changed (or lost).
banks A and B came loaded with patched from the factory, but these can be changed, loaded by tape with new sounds, or lost if the battery goes dead.
this is a vintage synth and does not use 'combis', 'set-ups' or such, so each patch in each bank is serpeate....that is, it does not 'use' any other patch sound.
questions (you can pm me or email me)
do you have the manual?
what synths have you had experence programming?
do all 32 bluegreen bars on the display light up?
does each orange bar light up when each of the 32 buttons are pressed?
bill
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Sun Apr 19, 2009 11:16 pm
jumpered all the bad connections and got a good tape dump. sounds like the factory patches. contacted this member. anybody else need a copy ??
- Confucius
Niijaooh
Gear: A6, Jp-4, Jp-6, Chroma Polaris II, D-50, TX-7, MKS-50, MW 1.
Post by Niijaooh » Sun Aug 02, 2009 1:27 pm
Sure if you can upload it as a .wav? Also since im in this tread I want to ask:
Is it normal that the only freaking parameter you can't control real time is the cut-off?
Anyone have the service manual? The seller had it, I payed a very high price for the synth and he still wouldn't want to me have it or make a copy (he claimed to have a scanner) even though the ax80 he sold me was his only one. He had no use for it. I don't even think he was a tech, the thing had what I hope was dried up chocolate milk (!) spilled inside and smelled like perfume haha. It also had the most noisy display board ever, I had to make a screen of tin foil and cardboard so it would "crosstalk" into the voiceboard. Cheers!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Sun Aug 02, 2009 1:57 pm
i'll give it a try. i'm very old-school. never made a .WAV file before. if success, I'll post here.
manual: best bet is http://www.transanalog.com. always gives me great/fast service.
As i told Denco: not sure these are 100% factory.
- Confucius
Niijaooh
Post by Niijaooh » Sun Aug 02, 2009 2:51 pm
Thanks! Yes I understand they may be altered patches.
Could you tell me if its normal that the cutoff can't be adjusted in real time? I have to retrigger the note to hear it.
I was looking for a pdf version of the service manual, but thanks anyway :D
EDIT: I have found out that its normal for the cutoff the behave that way.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Sun Aug 02, 2009 6:32 pm
will get mine off the shelf and check about the cut-off. but i'll bet you're right that it does not update in real time.
for PDF manuals try www.markglinsky.com
- Confucius
musicpants
Gear: Prophet 600
Juno 60
Akai AX80
Korg Poly800
Post by musicpants » Thu Apr 21, 2011 9:51 pm
I know I'm two years late on this one, but if anyone who received a tape with factory presets has converted it to .WAV, please contact me. Would L-O-V-E to get my AX80 A/B banks back. :D
Thanks!!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Thu Apr 21, 2011 10:48 pm
Welcome to the board.
I have given away all my tape copies...yes - stupidly even the master - but I may still be able to get something off of another AX-80 still on the shelf. I'll PM you if I do. Otherwise, get the service manual and start entering (lol).
- Confucius
musicpants
Gear: Prophet 600
Juno 60
Akai AX80
Korg Poly800
Post by musicpants » Thu Apr 21, 2011 11:17 pm
Thanks for the welcome and the reply! Great, let me know if you end up grabbing something; however, not sure if its worth the trouble. Surprising no one's done a digital conversion by now. But you're exactly right - may be time to start punching buttons :) Thanks again!
space6oy
Post by space6oy » Tue May 17, 2011 12:18 am
rhino does not forget. just emailed me these:
http://space6oy.com/AX80presets/
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Tue May 17, 2011 1:08 am
space6oy wrote:rhino does not forget. just emailed me these:
Thanks, friend. Hope this helps AX80-ites everywhere.
NOTE: the two files are the same data recorded at two different sample rates so you can use the one that loads best.
- Confucius
musicpants
Gear: Prophet 600
Juno 60
Akai AX80
Korg Poly800
Post by musicpants » Tue May 17, 2011 2:13 am
Thanks guys! Can't wait to try it out!
