SCI Multitrak Problems
synthesizerist
Post by synthesizerist » Wed Jun 17, 2009 4:30 pm
My multitrak has some major issues... It won't sound patches except one in unison mode for some odd reason and if you try to change a patch that isn't sounding it won't make a difference and still will not make a sound.
I did some online digging around and found this quote "If instead the instrument goes through a tune routine, counting from 1 to 6 in the Value / Program display, you have a problem." in a FAQ by Trevor Blake and this is exactly what mine does. I just wondered if since this is obviously a known a problem if anyone knew what the cause was (it doesn't go into it further in the FAQ).
synthesizerist
Re: SCI Multitrak Problems
Post by synthesizerist » Wed Jun 17, 2009 4:32 pm
Sorry, that quote is referring to what happens on start up it counts through as if it is tuning... But it will also do this randomly while I was trying to get different patches to work or changing parameters.
synthesizerist
Post by synthesizerist » Wed Jun 17, 2009 4:34 pm
OK... also I should've mentioned that I already replaced the internal battery hoping that was the problem...
hurfdurf
Gear: tr-707,tr-808,tr-909,tb-303,re-201,dc-20,juno60,mks30,ms20,pro-one,rx5,arp odyssey,majreverb,tx81z,spx90,etc.
Post by hurfdurf » Sat Jun 20, 2009 2:35 pm
Are you sure it's the right battery? Did you use ESD protection while replacing it?
Try holding down Program Record while hitting 8 and sounding the synth afterwards. If it works, you have a memory corruption issue, most likely due to a flat battery.
synthesizerist
Post by synthesizerist » Sat Jun 20, 2009 8:08 pm
Actually, this synth was like this when I got it and I replaced the battery with what was in there. I will try the test and see if that is what the problem is. Thanks!
synthesizerist
Post by synthesizerist » Sat Jun 20, 2009 8:56 pm
OK, I held down program record and pressed 8 and only track 2 sounds... I can scroll through different patches and they appear to be working (i.e. the lights over the tracks light up), but there is no sound- even on track 2.
Then I opened it up to see what battery was in there and it was actually replaced with a holder with two 1.5V alkaline batteries. I'm guessing that may be part of the problem?
Thanks for you help!
