my analog filter is not sending any sound out...help
mr_lerer
Post by mr_lerer » Sat Jul 11, 2009 11:36 am
Hi guys I will apreiciate any idea or advice
I have a Waldorf '4 pole mini works' analog filter which worked perfectly , I havn't used it for two months (it was plugged out from the electricty) yesterday I wanted to use it I plugged it in all the leds worked, I connected an audio
source in no sound came to the output its important to add that It no even the slightest noise fo the resonance
is going out completely silence...
any ideas ?
Thanks
pflosi
Re: my analog filter is not sending any sound out...help
Post by pflosi » Sat Jul 11, 2009 1:14 pm
make sure all modulations are off, make sure the amp is open, and if you dont use the stereo output make sure it's panned to the right side...
still nothing?
Mush
Gear: I have all the gear I need.
Band: Mush Orchestra / Rasmus Nyåker
Post by Mush » Sat Jul 11, 2009 2:01 pm
We call that a no-pass-filter and it is useful if you work with musicians that don't play your stuff the way you like them to!
tekkentool
Real name: Steve
Band: none currently
Post by tekkentool » Sat Jul 11, 2009 2:47 pm
Mush wrote:We call that a no-pass-filter and it is useful if you work with musicians that don't play your stuff the way you like them to!
oh yeah, i bought that module, i use it to record the sound of heavy air, grateful dead style.
mr_lerer
Post by mr_lerer » Sat Jul 11, 2009 9:16 pm
still nothing I made everything you said (pflosi) but still nothing.
thanks though
pflosi
Post by pflosi » Sun Jul 12, 2009 12:20 pm
doesnt sound too good. i guess u'll have to take a look inside
