roland jx - 3p user patch memory problems
I just bought Roland JX - 3P and have some problem. I design my own patches with buttons on synth panel and write to memory (C or D bank) like written in roland manual. All my patches are in memory while synth power on but after swiching off roland memory disappears all my programmed patches. I can play only factory patches and some pathes in C,D banks which were in memory before my programming. Could you explain me problem?
Re: roland jx - 3p user patch memory problems
The first thing is to check the battery inside..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
It's best to unplug the synth.....Test the battery (around 3v)...Look for any leakage or bad connections.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
- Pro5
- Expert Member
- Gear: Prophet 10 Rev 4 | Prologue 16 | JD-800
Yeah dead battery.. most likely cause. On the JX-3P it's not a button battery but a diff looking one (IIRC) so may need to custom fit a new battery with some wiring. Not a hard job really.
I posted some internal pics of a jx-3p in another thread of mine if you want to take a look at the battery location.
http://www.vintagesynth.com/forum/viewt ... 3p#p522295
The battery is the yellow thing in the middle of the PCB on this pic. It's soldered on. It should be possible to desolder this and solder on a button style battery holder in it's place.
