i am having some trouble with my moog little phatty. it is no receiving midi in correctly sometimes it work and sometime it doesn`t. i always had it hood up with my computer via my 128 midi express. with the operating system it came from the factory and i never have no trouble.
i upgrade it two weeks ego to the last version. it is running 2.02s version and it is a Moog LP Stage II, and when i connected for the first time the midi connected work fine them when i started to sequence it with the monomachine, them it just when completely quiet. i shut it off them on the trigger keys of the mono send it midi note on fine when i switch to record grid on it when crazy again.
but, the problem was no that it was no receiving midi note right, the four control out of the mono are set up to send controller # 1,2,3,4, them i started to tweak the four control just to see if, i can changed anything. i realize that CC 3 send volume midi data and, it was turn all the way down.
now, after all of that i keep struggled with this f**k thing. sometimes it work sometimes it go crazy, i even sent it the midi upgrade again. i even have some problem upgrading it. it was no receiving the midi firm ware upgrade at first it show an error message which i don`t remenber what it was.
after that no problem for a while till today, it was working find them i try to sequence it again with the monomachine and it was no responding to midi message. i have local control on so , i go to the master menu and, turn it on just to play it with its keyboard to see if, it work fine no it did not i stoke the keep couple of time them the message fatal keyboard over run appear. the f**k up thing is that when i turn it on again and connect the midi out from the prophet 08 it the prophet 08 trigger it fine.
i don`t think i have it set up wrong because i been able to sequence all the other synths fine with my mono without any problem.
i am freaking out with this thing. now, more that i just pull out my receive of purchase and, it was bought on the 01-26-09 so, it is still under warranty i wonder if, i should take it to the store so they can check it out before the warranty expired.
i will probably take it tomorrow but, i thought i ask here of what you guys might think the problem can be?
or if, i can get a helping hand from you wise VSE member?
i need help please can someone help me out?
thanks so much
