Cubase notes
Cubase notes
In cubase in want to filter everything but the note data on midi channel 1
- meatballfulton
- Gear: Logic Pro X
Re: Cubase notes
Which Cubase version?
In Cubase 4 filtering is in the preferences which makes it global to all channels on input.
Re: Cubase notes
hi, thanks for the reply.. ive just upgraded from cubase sx3 to 4..
i need my midified sh101 to receive note data only as i think other data is causing the notes to stick, on the same midi out put i have a kenton pro solo going to a sh09 via cv/gate and on the kenton midi thru to goes to the sh101 and then on a midi splitter cable a clock sink is going to my roland cr78
any help is welcome as im getting stuck notes all the time! ive tried hooking up the sh101 just to the master keyboard which worked fine so im guessing the problem lies with midi data comming from cuabase
