CS01 won't power on after cleaning
I opened my CS01 to clean it because the switches were getting a little scratchy, and when I put it back together, it would not turn on. I tried batteries and a 9v dc power supply. Any ideas on what I may have done to it? It worked just fine before I opened it. I've cleaned/fixed lots of synths before, so i'm pretty sure I didn't short anything. I'm admittedly not a tech, but never had something like this happen before.
- rhino
- Real name:bill
- Gear:keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo - Location:kentucky hills
Re: CS01 won't power on after cleaning
one things comes to mind: when synths have hard wires (to/from switches/jacks/etc) they are usualy very small-gague and can break at the solder joints....even inside the insulation. Opening an closing the synth can stress one over the limit.
- Confucius
- Confucius
Thanks for the tip, Rhino. I checked all of the conections, and everything seems solid. Unfortunately, it still won't turn on. I'll keep at it till I get something to happen.
