Oberheim ob-1
sam
Oberheim ob-1
Post by sam » Wed Mar 24, 2010 9:56 pm
There is no output...I think it's a problem with the memory section.
Even in manual mode nothing works..as the memory has stopped everything.
Any thoughts...There is loads of logic chips but where do i start..?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Steve Jones
Real name: Steve
Re: Oberheim ob-1
Post by Steve Jones » Thu Mar 25, 2010 1:12 pm
Start with the power supply. Always the first step in every repair like this. No point spending days looking for a computer fault if one of the supply rails is missing.
sam
Re: Oberheim ob-1
Post by sam » Thu Mar 25, 2010 8:35 pm
Cheers steve...The power supply is fine, It had a leaky battery but i cleaned it up and replaced it but it still locked up.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Steve Jones
Real name: Steve
Re: Oberheim ob-1
Post by Steve Jones » Fri Mar 26, 2010 2:06 am
Have you checked very carefully that battery electrolyte has not gotten under anything and eaten it away? It tends to track along traces and eat the copper away from under the laquer. Also check the power supply rails for ripple if you have a scope.
If you don't have a cheap oscilloscope and you want to do this repair yourself it would be a good idea to get one. If you have a multimeter, see if the pots on the top panel have 10V on one side and 0V on the other relative to ground (or between the 2 outer pins on each pot.
sam
Re: Oberheim ob-1
Post by sam » Sun Mar 28, 2010 7:27 pm
thank you steve...I will give that a try... :D
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Mon Jun 07, 2010 7:39 pm
Update.....I have replaced all the caps on the power supply and this should rectify any unwanted ripple and after 20 plus years it needed it anyway.
All the readings to the boards are correct inc the programmer.
The synth powers up with the second memory light on..
It won't change if i choose another inc the manual mode.
I only get a low rumble on the output.
Next (thanks steve) i check the pots ...
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Tue Jun 08, 2010 11:21 am
The problem is on the programmer board..I tried another board from a ob-1 here and it works.
It's full of those 4XXX chips..
I am just wondering how to test these chips...?
No scope but a very good multimeter.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Tue Jun 08, 2010 8:02 pm
I have found a possible cause...A CD4050 chip is not reading correctly and it's under the leaky battery.
I will replace it and see what happens..
Fingers crossed..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Wed Jun 09, 2010 6:06 pm
Here is something i am trying to work out...
The saw wave can be swept to a sine....Which part of circuit does this...?
http://www.electrongate.com/obfiles/OB-1-1342a.jpg
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Thu Jun 10, 2010 6:07 pm
This programmer board is reading higher values than it should.
I have been looking at the LM301 ...Pin 8 gives a different voltage between 0 to 13v every time it's switched off and on again...I don't think this is normal..?
Here is the board....http://www.electrongate.com/obfiles/OB-1-1341.jpg
Any thoughts on this..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Fri Jun 11, 2010 8:37 pm
The opamp is ok...The power supply is ok..
It's the programmer board...When the synth is switched on light 2 comes on.
If i touch a sensor and switch on it will light on that one inc the manual mode.
In manual mode it plays but no controls work.
So if anyone has experience of these problems...Please help... :ugeek:
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Sun Jun 13, 2010 9:56 pm
There is another strange thing.....On the schematics cem 3310's are used for the ADSR...I cannot find them on my ob here....I need to know if there are different versions and find the right schematics...?
Please anything might help...
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Sun Jun 13, 2010 10:31 pm
I just found out mine has discrete envelopes...So i need to work out what components do this..
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Fri Jun 25, 2010 7:45 am
I have replaced the 3086 which has solved the osc fault..The cable that supplies the main board with power was causing problems with the tuning because of bad contacts..Tried to clean it up but still not 100%.
Need to find a replacement...Anyway i need to find the part of the circuit that changes the saw wave to triangle..?
If you know...?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
sam
Re: Oberheim ob-1
Post by sam » Fri Jul 09, 2010 7:51 pm
I have now solved the problem with the saw to triangle wave...It was a faulty 3080 on the osc section.
The memory problem was a 4069 on the prog board..
SOUNDS GREAT NOW....Thanks for following and if you have any questions regarding the ob-1 and X ..
Just ask... :D
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
