I am fixing and restoring my multiman...I am trying to work out why the envelope section doesn't work.
The pots are fine...
I can't find any schems...
So any info would be great from anyone who has worked on one here...?
crumar multiman
crumar multiman
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
radek tymecki
Re: crumar multiman
SUPER...Thank you..I find it's the trigger to the envelope is not working...
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Re: crumar multiman
I noticed these are for the later S version..Mine is the mk 1..
Is there much technical difference..?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Re: crumar multiman
The problem was in the keyboard, I had to strip down and clean / calibrate the keyboard contacts.
The next thing is some of the key contact springs a getting old and less taught.
Are there any tricks to fix these..I have no replacements.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Re: crumar multiman
I found a solution for the springs...Must post photos to explain..
Next fault....On the bass section/piano...One note is out of pitch..
Checked the dividers OK
Voice board is OK
Any ideas...?
Voice board is OK
Any ideas...?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
Re: crumar multiman
It's solved...A wire going to the dividers was broken, it took some time but it's fine.
Just need to replace some caps and clean up the boards ....
I got this in a bad state but hearing it now it's all worth while.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
