connect different cases of a PAIA 4700
peonytele
Gear: Oscillators
Post by peonytele » Thu Jul 22, 2010 4:51 am
Hello everyone:
Just got the item from analoglsd, really enjoy it
and here is the question, hope some one could have a look, thanks:
the 4700 has 3 cases. When I use some modules in different case, I must connect the cases through ground input on the power supply, to get the modules work, or there is just wrong amp sound. Is this way right?
cornutt
Gear: 6th
Re: connect different cases of a PAIA 4700
Post by cornutt » Thu Jul 22, 2010 6:31 am
IIRC, the 4700 uses banana jacks for control signal routing. On any modular that uses banana jacks, yes, you must have a common ground between the cases. So what you are doing is correct.
peonytele
Gear: Oscillators
Post by peonytele » Thu Jul 22, 2010 6:43 am
Got it.Thanks a lot!
