You just need a midi controller that can send CC codes assignable to each pot. I have a midi guide, user manual, and schematic for the MAX. It should tell you all you need to know. Upon shutdown however, all info will be lost (yes, presets 80-99), so it is best to backup any important patches. I shouldn't have sold mine.BrassTeacher wrote:Hi All,
A search of past posts turned up nothing, so here goes: Has anyone found a viable way to connect any type of controller, midi or otherwise, to a Sequential Circuits MAX that would allow real-time tweaking of parameters?
In other words, with all the new midi controllers that have faders and rotary encoders, are there any that someone has successfully set up and used with a MAX? Due to the similarity, I'd even be willing to try one that is known to be compatible with the SCI Six-Trak...
SCI MAX Programming
- sequentialsoftshock
- Real name: Zayne
- Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
