LEDs for the UltraProteus
vcs3
Gear: BitOne,DX7II, M-1000, ESQm, Procussion, NanoSynth, VL1, P2500, K5000R, FS1r, JX-3P, Ju-60,HR-16, CZ1000, RX-5,K2600S, Nord G1r, G2, XL-7, Shuthri-1
Post by vcs3 » Tue Aug 31, 2010 10:53 pm
Hi,
I have UltraProteus tha as damage in the transport and the LEDs where broken,
where can I find that type o LEDs?
Thank you in advance.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: LEDs for the UltraProteus
Post by rhino » Wed Sep 01, 2010 12:05 am
don;t quite understand what you need. Did you mean the LCD screen display? This should be a rather standard item. Once you get the exact size and connectios, and mounting location, you should be able to get one from nearly any electronic distributer. You could even try emailing E-MU...they may still supply them.
EDIT:
found this link to a parts source:
http://www.eprelectronics.com/store/htm ... index.html
- Confucius
vcs3
Post by vcs3 » Wed Sep 01, 2010 12:20 am
Hi,
I need the LEDs wich are very strange LEDs, the display is fine.
I already contacted EPRelectronics.
thank you.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Sep 01, 2010 1:10 am
tell me more about the LEDs.
- Confucius
vcs3
Post by vcs3 » Wed Sep 01, 2010 3:20 pm
rhino wrote:tell me more about the LEDs.
A picture tells more than a 1000 words:
Thank you.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Sep 01, 2010 4:55 pm
thanks. measure the diameter of the 'stem' (top part). these fit into a 2.4mm hole:
http://www.kingbrightusa.com/images/cat ... 443HDT.pdf
- Confucius
vcs3
Post by vcs3 » Wed Sep 01, 2010 6:35 pm
rhino wrote:thanks. measure the diameter of the 'stem' (top part). these fit into a 2.4mm hole:
Great work rhino, thank you, but where can i buy de LEDs?
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Sep 01, 2010 7:45 pm
see if any of these distributers are near you:
http://buyersguide.ledsmagazine.com/Sea ... id=3567245
the Kingbright part # is WP443HDT
- Confucius
vcs3
Post by vcs3 » Thu Sep 02, 2010 8:13 pm
rhino:
that LEDs don't fit, the one in UltraProteus are 1 mm of diameter in the tip, and that ones have 2.4 mm.
still searching...
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Thu Sep 02, 2010 10:21 pm
Wow. That's SMALL. Could you change them all and drill out the panel holes to fit the 2.8mm? Maybe find some 1 mm plastic rod and glue short piecec to the existing LED bases? As a last resort file/sand down the tube to 1 mm?
- Confucius
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Fri Sep 03, 2010 12:10 pm
If you can find the service manual or someone that has it, you might be able to get the part number...
vcs3
Post by vcs3 » Fri Sep 03, 2010 3:21 pm
rhino wrote:Wow. That's SMALL. Could you change them all and drill out the panel holes to fit the 2.8mm? Maybe find some 1 mm plastic rod and glue short piece to the existing LED bases? As a last resort file/sand down the tube to 1 mm?
My mistake it's 2 mm in diameter.
Here in Portugal I find a supplier that sells this one http://uk.farnell.com/multicomp/mcl223m ... dp/1581105
I think it will fit.
Thank you .
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Fri Sep 03, 2010 4:08 pm
Great !
- Confucius
