machinedrum quantization?
can somebody please explain how can I turn quantization off?
cartesia
- Expert Member
- Gear: Octatrack
Bass Station 2 - Band: TBA
Re: machinedrum quantization?
Unless there is a way to set a delay/offset for each step, there is no 'off'
- Syn303
- Expert Member
- Gear: Quite a bit...
- Band: Syn303
You can't, it either locks to it's own internal tempo or to an external tempo. You can do TAP tempo though.amatsov wrote:can somebody please explain how can I turn quantization off?
yeah...but I want to make a beat thats not 4/4...and I cant figure out how to make one.
it makes quantization so its not what I tapped in.
- Syn303
- Expert Member
- Band: Syn303
So you want make beats like 3/4 (triplet time etc), FUNCTION+SCALE, then you can alter your scale ie 12/16 for 3/4, and if you have the latest OS in, you can add shuffle, by moving the cursor right to where it say 1x, use the cursor down key to get either 3/4 or 3/2, or up for shuffle 1x or 2x. If that doesn't satisfy your needs, sell your MD and get an MPC.
thanks syn, thats the info I wanted!
- Mush
- Gear: I have all the gear I need.
- Band: Mush Orchestra / Rasmus Nyåker
Or you can sequence it via midi....
cartesia
- Expert Member
- Gear: Octatrack
for the record that's not turning quantization off, it's changing the time signature..
most step sequencers can't turn off quantization, but most can change the time signature.
