broken screw posts on synths
man-009
- Real name: Timothy
- Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
The Curse Of Lilith Ratchet on TUBI - Band: view so cruel
anyway to fix broken screw posts on the back of synths to keep the back plate secure? was thinking of super gluing some kind of small plastic solid cylinder to the broken posts like the old posts... then put screws through them! i think it will hold. i can picture it all in my head but hard to describe it. and harder i bet to do..lol. to find such a piece of small solid plastic rod cylinder though may be the hardest part. arrrrrgghhh!!!!
- sequentialsoftshock
- Real name: Zayne
- Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
Re: broken screw posts on synths
Hmm... Carbon111 did a similar task when he restored his Pro~One.
http://www.carbon111.com/pro1.html
"I have some 3M DP-805 handy, a non-epoxy, high-shear-strength (2780psi) glue that retains some flexibility so it will be perfect for the job:"
It's a little more than a quarter of the way in. If this looks suitable, I believe he is a member here, and may see this to further add advice.
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
I have had good luck with a 2-part repair called "PLASTEX"
Powder and liquid. Mix and it hardens.
Rather pricy, but works great.
www.plastex.net
www.plastex.net
- Confucius
- Confucius
man-009
- Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
thanks. will check those out asap! nothing worse then broken screw posts...
