Yamaha TX-7 wont fire up?
man-009
- Real name: Timothy
- Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
The Curse Of Lilith Ratchet on TUBI - Band: view so cruel
anyone know what it could be? thanks. looks mint but wont turn on. maybe a battery issue? may need a new one? not sure if that would make it not turn on? sorry, just guessing here!
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Re: Yamaha TX-7 wont fire up?
Was going to be smarmy and say "Pull out the choke"
Does it use a wall-wart? If so: Correct one? Working? Check that the jack in the back of the TX has not been damaged by being dropped on the plug, or someone pulling sideways on the cord.
Regular AC cord: Open the case up and check for internal fuses blown.
Was it working before, then quit?
- Confucius
- Confucius
gcoudert
- Expert Member
- Real name: Gilles
- Gear: Roland Fantom X7 with Ultimate Keys expansion, Yamaha TX802, Roland JP-8080, Tascam DP-24SD.
Even with a dead battery, the unit would still power up. You would lose your patches and their names would be replaced with odd characters in the display. It's definitely a power issue. Check the fuse first!
GC
man-009
- Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
aaahhhhh! yes, it's the wall-wart wire. will pick a new one up. somehow it got sliced? thanks.
