Contact for Music and More (MAM) : Power Supply Info needed.
expermusic
Post by expermusic » Wed Nov 17, 2010 1:48 am
I need to get a replacement power supply for a MAM MAP1 arpeggiator. All that I know is that is should be 12V, but I don't know the mA or plug size.
A) Does anyone have this unit and could they tell me what the power requirements are.
B) Does anyone know if there is info/contact for MAM?
I know they were supposed to be restarting as a company but the website still says under construction. Did part of MAM become Vermona?
Thanks for any help!
MFB Kraftzwerg, Euro Modular (w/ Noisering, Maths, Tame Machine, Doepfer A-143-9, A-154, A-155, A-160 so far) Nord Modular G2, Elektron SPS-1UW, Mini-kp, Novation Launchpad, NI Maschine, Novation Remote Zero SL MKii, Macbook Unibody 2.4
space6oy
Gear:vimpat, citalopram & vitamin D.
Re: Contact for Music and More (MAM) : Power Supply Info nee
Post by space6oy » Wed Nov 17, 2010 1:53 am
i haven't had a MAP1 but have a bunch of other MAM gear, will get back to you on the mA but i'm 99% sure their plug size is the same as a standard boss 9v DC adapter.
also this belongs in the help section.
expermusic
Post by expermusic » Wed Nov 17, 2010 2:34 pm
Thanks for getting back to me. If you have a chance to check that, I'd really appreciate it.
speak_onion
Real name:Dan
Gear:Octatrack, G2 Engine
Band:Speak Onion
Post by speak_onion » Wed Nov 17, 2010 4:53 pm
The plug size on my MAM rack gear (Warp9 and RS3) is 2.1mm barrel, the same as boss or 1spot or whatever common power plug. I daisy chain both units off of a single Jameco 12V AC power supply using one of the 1spot daisy chains. Not sure what current the Jameco is capable of. You could just grab the biggest 12V AC 2.1mm power supply you can find/afford at a place with a reasonable return policy.
space6oy
Post by space6oy » Wed Nov 17, 2010 7:00 pm
agreed. & the originals are 12v AC 700mA.
Real name:Tomas Mulcahy
Post by madtheory » Wed Nov 17, 2010 8:28 pm
Alesis 9V AC PSUs work fine with MAM gear. That's what I have on the LM122 mixer for about 4 years trouble free.
space6oy
Post by space6oy » Wed Nov 17, 2010 10:26 pm
those are 830mA, right? don't have one in front of me...
Post by madtheory » Thu Nov 18, 2010 10:45 pm
That's correct.
expermusic
Post by expermusic » Thu Nov 18, 2010 11:13 pm
Well thanks guys. I'm going to try and find an alesis first. So, does the fact that there is a slight difference in mA matter?
space6oy
Post by space6oy » Thu Nov 18, 2010 11:34 pm
with some things it definitely does, others not so much. not sure about MAM gear but know the modFX don't like any power supply but their own...
Post by madtheory » Fri Nov 19, 2010 12:57 pm
expermusic wrote:Well thanks guys. I'm going to try and find an alesis first. So, does the fact that there is a slight difference in mA matter?
madtheory wrote:Alesis 9V AC PSUs work fine with MAM gear. That's what I have on the LM122 mixer for about 4 years trouble free.
