ROLAND S-550 stuck with one sample
ColorForm2113
Gear: tin cans and rubber bands
Band: Me twiddling in the corner...
Post by ColorForm2113 » Thu Nov 18, 2010 8:19 am
ok so ive been trying to stop obsessing about other gear i cant afford and get back to working with what i have. and after fooling around with sampling some nice moog pads from my micro, i decided to put together a synth drum kit....well in the s-550's internal memory i managed to create a kick drum (sampled to I11), snare drum (I12), closed hi hats (I13), and toms(I14), i then saved the set (Set I) to a disk and the names all came up, but every sound is the kick drum sound. ive tried a few different disks and and have had the same problem so its not the disk, so its either me or the machine. anyone else have this problem? its been a very frustraing night and im determined to get this to work :x
thanks in advance
EDIT: I tried changing the midi chanel and also tried changing the patches around and i still only get the kick drum sound....
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: ROLAND S-550 stuck with one sample
Post by rhino » Thu Nov 18, 2010 4:59 pm
Totaly bogus advice since I've never had one.
Kurzweil samplers have a feature called 'opaque layer' that causes one sample to cover up all the others if the key ranges overlap. Any chance of something like this?
- Confucius
ColorForm2113
Post by ColorForm2113 » Thu Nov 18, 2010 5:38 pm
There is a function called mix where you layer 2 samples on top of each other, but that creates a new sample spot and you have to manually do that for each sample. Its probably something really stupid and obvious that im missing. Thanks for the input though.
ColorForm2113
Post by ColorForm2113 » Fri Nov 19, 2010 2:08 am
Update, I've managed to get the samples I made saved as "tones" but I can't get them to come up on the play menu, but I can edit them...its progress I guess....
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Fri Nov 19, 2010 7:17 pm
Again bogus.
In the wonderful world of Roland (at least the "D" series) don't you have to put the "tone" into a "patch" to make it play? (sold my D-110 and manual a long time ago)
- Confucius
D-Collector
Post by D-Collector » Fri Nov 19, 2010 8:12 pm
In my S-330, you sample -that makes a tone, then open menu and choose edit split, there you can assign tones to a patch. As Rhino said, you have to assign tones to a "patch" before you can play them normally.
ColorForm2113
Post by ColorForm2113 » Fri Nov 19, 2010 11:09 pm
Ahhh ok. Thanks a lot guys ill have to try that tonight when I get home.
ColorForm2113
Post by ColorForm2113 » Sat Nov 20, 2010 7:52 pm
Huhzah! It worked! I was skipping over the split step, as I thought you only needed to do that if you want 2 tones to be played on a patch, but you need to asign the keys for any tone to be played. Thanks for all the help, I can now miss sleep due to creating music instead fighting with machines lol
