Akai S950 Floppy
Spadz
Real name: Francis
Gear: Synths, samplers, guitars, bass, drum
Akai S950 Floppy
Post by Spadz » Wed Feb 09, 2011 5:39 pm
Hi,
Anyone knows where I can find a replacement drive? Mine seems to have a mecanical problem where it doesn't recognise that there is a disk in it...
I found another question in the forum with no answer dating back to 2009. But I'm going to take a chance.
Very hard to find that thing.
Thanks
If you don't know what you are doing, why are you doing it?
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Akai S950 Floppy
Post by rhino » Wed Feb 09, 2011 6:55 pm
Don't know if you tried Route66Studios.com
They don't list one, but I sent them an email asking. Will post the replay here.
- Confucius
Spadz
Real name: Francis
Post by Spadz » Wed Feb 09, 2011 7:48 pm
Thanks
I saw the listed a S900 drive, but it seems it is different. I've been searching for days on the net and the conlusion is that it will be a PITA to find!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Feb 09, 2011 8:13 pm
Did you try http://www.vstservice.com ?
The site says 'out of stock', but you might keep bugging them.
- Confucius
Spadz
Real name: Francis
Post by Spadz » Wed Feb 09, 2011 8:25 pm
Yeah I saw them.120$ for a floppy is a ripoff. And they overcharge shipping.
I found out about them in some forums and they pretty much all feel the same...
I found some French guy who is modifying floppies for many machines. It would cost me half of vstservice even coming from France. I contacted him and he told the support for the S950 is halfway done.
I have a S900 wich works and I'll use this one till I find a drive.
It sucks because I have the full ram upgrade on the 950!
That's life with old stuff.
Keep me posted if you see anything.
Thanks Rhino.
Spadz
Real name: Francis
Post by Spadz » Thu Feb 10, 2011 8:10 pm
A little update.
I just talked to a tech I know and he told me it could be the spring of a floppy metal protector. When I bought the S950, there was one stuck in the drive and it pulled out easily. Then everything worked fine until sudennly I was gettin that "Drive not mounted" error.
There is a small spring holding that thing closed on the floppy disk, and my tech thinks it might be stuck somewhere keeping the drive from recognising the floppy disks.
Seems I'm opening up an S950 tonight!
