esq-1 buzz
nikko
esq-1 buzz
Post by nikko » Sun Feb 20, 2011 8:43 pm
hello explorers!
my first post is a question because today i turn on my beloved esq-1 and a "buzz" come from the power
supply (in the era of the esq-1 logo)
and it's makes me panic!
any ideas??? :?
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: esq-1 buzz
Post by rhino » Sun Feb 20, 2011 9:43 pm
Welcom to our crazy world !
If the screen does not light, or smoke comes out, or fuse blows...you've got trouble.
If everything works and sounds fine, you may have a loose or failing xformer. They still can be found and are not a big hassle to change, but if you're not used to working on 120v AC cricuits, best take it to a tech.
Another possible - but rare - problem would be a shorted recifier on the power supply board.
- Confucius
nikko
Re: esq-1 buzz
Post by nikko » Sun Feb 20, 2011 9:58 pm
thanks for the replay !
yes evrything work fine i guess i will take it to the tech.
bay the way does the outputs support to be low?? (i connected the esq-1 to a line level -10dbv 10k impedance i comparing the level to my "hige gain" evolever)
p.s my next topic going to be : analog vs VA synth's so be paper for something fresh!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: esq-1 buzz
Post by rhino » Sun Feb 20, 2011 11:23 pm
There is a very small chance that the xformer has developed a shorted winding that is causing the buzz AND causing lower voltage to the analog side of the synth.
- Confucius
nikko
Re: esq-1 buzz
Post by nikko » Sun Feb 20, 2011 11:47 pm
ok i'm going to the tech guy..i also found an interesting article i thought it's can be useful: http://www.pic101.com/ensoniq/pswoes.htm
oh and i just jokeing about the "analog vs VA synth's " its been like three eras since i discover VSE i'm realy love this forum
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: esq-1 buzz
Post by rhino » Mon Feb 21, 2011 12:28 am
Good. The condensers do fail with time, but USUALY short and explode - blowing the fuse. Do you have a METAL pr a PLASTIC chassis ESQ ?? In the plastic (later) version, the transformer is fastened to the botton of the case with 'Pop' rivets. They should never come loose. On the metal box style, IIRC the xformer is bolted down... maybe these have worked loose and the xformer is vibrating against the bottom.
- Confucius
nikko
Re: esq-1 buzz
Post by nikko » Mon Feb 21, 2011 7:21 pm
i got the plastic one..
today i call a company name "single" they got a electronic lab and they fix and build a lot of audio gear after a smalltalk he told me not to turn on the esq-1 and that my real 1.concern shold be about the digital side of the esq (in general)
man it never ends with the old goodies.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: esq-1 buzz
Post by rhino » Tue Feb 22, 2011 2:00 am
Again, if the display is correct, the buttons work, keys play the right notes/sounds, etc., then the chances of digital problems are low. Don't know this guy from Adam, but watch yourself anyway.. Don't let him tell you that some or all the voice chips are bad and demand an arm and a leg for replacements. How loud is this buzz? (insect, electric fan, electric razor, power sander?) CAn you feel vibration? Does lifting one end of the synth change it? What frequency is it near (60Hz, 120Hz, higher?)
- Confucius
