Page 1 of 2
Has anyone tuned a pro-one..?
Posted: Thu Apr 07, 2011 8:14 pm
by sam
Just fixed a pro-one....It had many problems and all the trimmers were messed with ect.
I have done the tuning procedure from the manual...But it's still not getting there.
The cv scaling is fine.
Any tips or insight or moral support needed.. :D
Re: Has anyone tuned a pro-one..?
Posted: Sun Apr 10, 2011 5:19 pm
by sam
Still not tuning... :?
Posted: Sun Apr 10, 2011 6:31 pm
by Solderman
Only thing I can suggest is make sure the pitch wheel is centered, and you are getting continuity from the master tune pot. Might want to check the +15 and -15 volt supply sources too.
Posted: Sun Apr 10, 2011 8:07 pm
by sam
Thank you solderman.....Everything checks out that you mentioned.
On the set up guide...You tune osc A with osc B NOT tracking the keyboard...?
Posted: Sun Apr 10, 2011 9:06 pm
by Solderman
The tuning procedure does mention it, but I'd guess it shouldn't matter since the keyboard voltage is buffered. I think they recommend that so you can have a fixed tone for tuning Osc A, without an external tuner. If you've done everything in the procedure and the mains voltages check good, then it will likely need repair.
Posted: Sun Apr 10, 2011 9:23 pm
by sam
I feel it's me and not the synth...I will try again.... :D
Posted: Mon Apr 11, 2011 10:11 am
by sam
I tried again but no success ..
Should I....Change the power supply caps and the trimmer pots..?
Something is unstable...Any thoughts....????
Posted: Mon Apr 11, 2011 2:45 pm
by Solderman
Doubtful it's either of those causing tuning instability. Best get it checked out by a tech.
Posted: Mon Apr 11, 2011 6:44 pm
by sam
The so called techs around here are very bad....I enjoy fixing my own synths and never have needed a synth tech.
Anyway I have noticed some bleed through on osc B.
I have changed the caps and it's not too out of calibration now....I just need to make it perfect.
Posted: Tue Apr 12, 2011 11:46 am
by sam
I cleaned the switches again and found a bad solder joint on the osc B section...It is now tuning ok.
Posted: Tue Apr 12, 2011 4:52 pm
by rhino
Good work.
Sharing my Mantra:
"Aint vintage FUN ???"
Posted: Tue Apr 12, 2011 5:54 pm
by sam
Cheers Rhino....I spent some time on fixing it's initial problems and then tuning is just a finishing touch (I thought)
Anyway it's sorted and sounds good.
I had to fix the crappy membrane keyboard. I found a way of doing this by wrapping tape around the part of the key that touches the bubble...It seems to work...So far..
After this fix I can give some tips on how to work on a pro-one.. :idea:
Posted: Tue Apr 12, 2011 8:50 pm
by Solderman
+1 well done on finding the problem. I've got one of my own with my CS-15 currently. Noisy VCA's, even after changing all the electrolytics. Guess it never ends.
Posted: Tue Apr 12, 2011 9:18 pm
by sam
Cheers Solderman.....What do you mean by noise...?
Can you hear it from the osc...What i mean is have you detected where it starts...?
Posted: Wed Apr 13, 2011 3:13 am
by Solderman
Sent you a PM
